fag lighter usb port
steve_k
Post Fri Oct 15, 2021 11:45 am
morning folks.
finally decided to do something about the non working fag lighter in my e30.
it's not worked all the 14yr's i've had the car,
so i've decided to go down the route of fitting a usb port in it's place so i can use a dashcam in the car,
thing is the wiring for the lighter is working perfectly & seeing as i don't smoke in the car it made sense.
has anyone else done this?
onthames
Post Fri Oct 15, 2021 2:19 pm
morning folks.
Good idea but for a dashcam I wired mine into the power for the check panel as its right where you'd have a dashcam. I used a garmin Mini dashcam and it works perfectly. Probably easier than running a cable from the cig lighter
fixedwheelnut
Post Fri Oct 15, 2021 4:12 pm
I hard wired my dash cam but also added a double aux power socket with two USB ports in my glovebox.
steve_k
Post Fri Oct 15, 2021 6:15 pm
i've been thinking of hard wiring a dash cam in But my idea with the cig lighter/usb port is so i can use my sat nav & charge my phone.
off to have a look for a hard wire kit for the dashcam....................
