power cable installation???
dark_sounds
Post Tue Jan 24, 2006 12:15 pm
how do i get some 0awg power cable through the bulk head of a 318is??? anyone advise??? i read the articles section, said to go through the drivers side,, but which gromet to use?? etc :)
anyone help me?? been a month without my sound system and im getting bored.... has resulted in putting my foot down more :twisted: need bass to calm me down a bit ;)
nav786
Post Tue Jan 24, 2006 12:31 pm
i went thre the passenger side. look near the fuse box, just below it and you'll see some wires going threw.
FOR SALE
SONY PSP'S £100
dark_sounds
Post Tue Jan 24, 2006 2:02 pm
looks abit small for a 0 awg??? am i looking at the right one?? would be preferable fort the driver side, as it would save me 2 meters of 0awg power.. whcih is quite expensive :)
nav786
Post Tue Jan 24, 2006 4:43 pm
look behind the battery, you should see the wiring harness going threw.
FOR SALE
SONY PSP'S £100
JAMZ
Post Wed Jan 25, 2006 6:07 pm
I went from behind the glove box,if you pull the carpet back a tad your see a rubber grommit with cables runing through the bulkhead..
Remove the grommit byt slicing it with a stanley(be carefull),then add another hole to it which will take yer Power cable,then fit the grommit back.. :)
Its an easy task and it still leaves all the sound deadening in place without making any more 'open' holes to yer engine bay
hope this helps
nav786
Post Wed Jan 25, 2006 6:11 pm
thats the same as i did jamz.
FOR SALE
SONY PSP'S £100
JAMZ
Post Wed Jan 25, 2006 6:29 pm
Oh yea!
:mad:
dark_sounds
Post Wed Jan 25, 2006 10:31 pm
hm am i looking in the wrong place then???
is it big enough for a 0 gauge cableing to go through???
JAMZ
Post Wed Jan 25, 2006 10:58 pm
mine did.. and its the only grommit as far as i know Behind the Glove box that leads to the engine bay
nav786
Post Thu Jan 26, 2006 1:41 am
take your glove box out (easy) and you will see it. you will have to pierce the grommit, and poke a bit of wire threw. its easier to spot it from the engine bay this way
FOR SALE
SONY PSP'S £100
dark_sounds
Post Thu Jan 26, 2006 9:54 am
is it the same on the IS, i just had a look and theres loads of stuff blocking it from the engine bay... also,,, to remove glove box its the 3 nuts on the bottom right?
nav786
Post Thu Jan 26, 2006 12:38 pm
there is one nut in each corner at the bottom, and when you open the glovebox there is one nut in each corner. the grommit and hole to bonnet is just behind the carpet.
FOR SALE
SONY PSP'S £100
ad318i
Post Thu Jan 26, 2006 5:28 pm
That how i did it
