Alright guys.
So I have been googling the hell out of this and found a few results but nothing I feel comfortable doing, i want to upgrade the sound system in my e30 Cabrio and put a small subwoofer in )not after heart skipping bass just decent quality)
I have seen people hacking up the rear bulkhead and putting subs in that but I am concerned for the structural rigidity doing this.
The problem is I cannot just put a subwoofer in the boot as the double bulkhead design pretty much isolates the sound and just rattles the car with little to no bass coming through - even more so with the roof down!
There is not enough space under the seats for an underseat subwoofer.
So what other options do I have here to upgrade the system?
Craig
Subwoofer placement in a CAB
chu346
How much boot space are you willing to give up?
padi
if you take the carpet out of the rear of the boot, you can squish a wedge shaped ported box in there. it also helps o vent the bass through into the cabin. I used to have this exact setup, with two 10" subs and a 1000w amp. worked really well, although like you say it does rattle a tad. ive currently got two 8S there, in a similar design, but I suspect to get the volume that i want back, ill have to go back to 10"s again.
Cheers Chris.
Cheers Chris.
- E30 Zone Meets/Events Team
