Speaker size
coldo
Post Fri Dec 30, 2005 1:34 pm
Alrighty,
What sized speakers are standard on the parcel shelf of an e30?
Is it a case of pulling the old ones out and putting new ones in?
Will i get much better sound quality from uprated speakers, but still the same size?
Cheers :D
Grantley
Post Fri Dec 30, 2005 3:01 pm
If its just a normal e30 the speakers are 13 cm (5.25 inch) front and rear. I kept to the standard size and bought good qaulity new ones (Vibe front and back), I also soundproofed the whole rear shelf and bolted 18mm MDF pieces under the shelf to give me a solid mounting for the speakers. Soundproofed as much as I could in and around the kick panels, I'm very happy with the way it sounds !
Royalratch
Post Tue Nov 21, 2006 5:51 pm
Did you brace the MDF panles to he body somehow or just had those hanging off the parcel shelf?
Falkster
Post Sun Nov 26, 2006 2:53 am
Been thinking about this for a while and the views Ive had were to replace with better quality standard sized speakers unless you specifically want to get bigger speakers (6x9s)
