radio removal
alfa12177
Post Fri Jan 31, 2014 5:40 pm
hi.want to remove the radio from the car. but cannot see any holes to push a removal tool into.its a pioneer unit circa 1988 fitted when car was new it has a handle on the front so looks like it should just pull out but dosent .any ideas thanks chris
miniblob
Post Sun Feb 02, 2014 12:33 pm
If you're still stuck, ask on the talkaudio forum - someone there will definately know!!!
Pretty sure the ones with the handle did pull out, but I would assume there is some kind of easy release button on the front panel or somewhere - otherwise it would just fly out when you accelerate!!!
327 Touring with bass!!!
