SE Sideskirts
Razza
Got a pair of these that finally I'm ready to put on the car, got them with the white stud fittings that you need to clip on once you've drilled holes into the side....are there any other fittings or clips as I'm not sure that the studs will hold them on....any advice?
Demlotcrew
There are clips that clamp the skirt to the bottom of the sill.
Andrew
Andrew
Razza
I don't think I got those with them - where would I get them from?, I was hoping the guy at my bodyshop will be able to improvise something....?
Grantley
When I took mine off to do a bit of work there were a few of the clips missing, went to my local breaker's and they had some, gave them a good clean up and jobs a good un. I would try to avoid permanently fixing them on incase you ever need to take them off again !
JoeP
- Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
I'm guessing the clips are similar to the ones that hold the front spoiler lip in place. In which case you can get them from the stealers for pennies.Razza wrote:I don't think I got those with them - where would I get them from?, I was hoping the guy at my bodyshop will be able to improvise something....?
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness
