This is the back :
It has controls on the front panel for a CD Changer setup but don't know if this can be used to control the Ipod or not ? Guessing this connects into the black DIN socket ?
Or is it just the case that I can connect the Ipod via the RCA IN ( on the lead ) that would have been used for the CD changer and select the songs via the Ipod itself ?
I'd rather use the rear RCA connection than the Aux in on the front panel so I just have the ipod connector poking out from between the dash and centre console rather than having it plugged in at the front - looks neater and I understand RCA connectors give better quality than a 3.5mm headphone jack input.
Anyone got any tips ?
Are the other RCA connectors labelled pre-out for an Amp ?
