Which wheels
vanos
Post Tue Nov 02, 2010 8:29 pm
Putting a 5 stud set up on my touring, want to keep the wheels BMW and wondered if anybody had any knowledge of 5 stud wheel fitment to a E30.
The wheels I like are, E34 M5 throwing stars, E36 M3 contour (from a 4 door evo), and E36 M3 sunflowers.
Would there be any issues with staggered fitments and what size tyres would be best.
Mark
mrLEE30
Post Wed Nov 03, 2010 6:56 am
BBS Style 5's in 17 inch, as seen on the M3 at top of zone page!
Post Wed Nov 03, 2010 12:22 pm
Depends on which 5 stud set-up you will running, E36 stuff or E30 M3 stuff. Offset's required are different.
You want high offset (E36/E46) wheels if you are running E36 M3 Evo stuff.
vanos
Post Sun Nov 07, 2010 8:54 pm
ImysE30 wrote:Depends on which 5 stud set-up you will running, E36 stuff or E30 M3 stuff. Offset's required are different.
Cheers Imys
Running E36 M3 evo front and Z3 rear, M5 E34 stuff no good then ? is it basically E36 stuff then ? can I fit staggered wheels or do I need a set of the fronts only ?
Whats the max width I can get away with ?
Sorry about all the questions but it should save me a lot of time when buying wheels, don't want to buy the wrong width and offset wheels and waste time and money.
Post Sun Nov 07, 2010 8:58 pm
E36/E46 wheels will be a better fit assuming you have a normal E30, non M3 kit?
You can fit staggered wheels, just depends on the offset/width of the alloys. Max width depends on the offset/width/tyre size etc.
You may need to roll/flare the arches if you want to go really wide, 9J plus.
Something like E36 contours
vanos
Post Sun Nov 07, 2010 10:42 pm
ImysE30 wrote:E36/E46 wheels will be a better fit assuming you have a normal E30, non M3 kit?
Thanks Imys
I would like some M3 sunflowers or M5 throwing stars, though the M3 contours would do as well. :cool:
Post Sun Nov 07, 2010 10:45 pm
No problem, good luck with the search 8)
