Hi All - I called the dealers today to order some pods, he said there were two types. Once running at 8ohms and the other had no info.
So I called the local ICE specialist who said its probably not the 8ohm one as that needs a woooofer (no...not a dog).
So I called the dealer back who said the 8ohm was the standard..aghhhh
Can anyone shed some light on this..I do have the cable behind the triangular plate.
Thanks in advance
estee
Tweeters...again
A1BMW325iSport
mine are also 8ohm mate
steedymorgan
should be 4 ohm for a car 8 ohm home stuff
325ise good but needs more power lol
how do i get my pics on here lol!!!!!
http://i15.photobucket.com/albums/a383/ ... MW325I.jpg
Danstable
The ones in my pods are 8 ohm
placey
8 ohm tweets will run just fine no problem. if you're putting them in the door triangles you'll probably not want them too loud as they're a bit close to the listeners ears - maybe hence the 8 ohm rating.
paul
paul
i saw a doctor and she gave me some pills....
estee
Thanks for all the responses, I've sourced a pair now, not from the stealers as they only have one side available (even when looking from germany), I eventually went for the 8ohms options
Estee
Estee
