Sound proofing
Post Sun Aug 15, 2010 3:58 pm
How does this stuff work? There are gaps around my speaker which I thing is degrading the sound quality.
mrcool
Post Sun Aug 15, 2010 11:09 pm
Are you talking about the dynamat type stuff. I started applying this today. You apply it to the metal panels behind and around the speaker area (or everywhere if your rich/going OTT) To deaden the sounds/quieten road noise/reduce vibration. Here it is applied to the rear wheel arch below my rear speaker.
miniblob
Post Tue Aug 17, 2010 1:58 am
If you mean the way the fronts mount, you are right Blitz - they would sound better 'sealed' in!!
None of the speakers i've used recently have fitted properly and i keep thinking about making something like a 3mm mdf mounting plate, that exactly fits where the front speakers mount. I'd then seal that in and mount the speakers on that!!
It's a nice idea, but will i ever get round to it..............
327 Touring with bass!!!
TouringTash
Post Tue Aug 17, 2010 2:19 am
how much does dynamat weigh mr cool?
318i Touring
miniblob
Post Tue Aug 17, 2010 7:41 pm
Couldn't give an example of weight, but it's not light!!!!!
Having said that, i doubt a bit behind/around each speaker would be noticed in anything but the lightest stripped out machine!!
TouringTash
Post Tue Aug 17, 2010 7:51 pm
was thinking about making a europe cruiser with a touring and a 2.7 and was thinking of using something like this to help keep the noise levels down, along with other fancy ideas.
ie suede roof lining winkeye
318i Touring
mrcool
Post Tue Aug 17, 2010 11:37 pm
TouringTash wrote:how much does dynamat weigh mr cool?
2.2kg per sq/metre
TouringTash
Post Wed Aug 18, 2010 12:25 am
cheers fella.
bloody hell thats nearly 35kgs very approx to do a touring.
and yes I had worked out the price 8O
but if its that good.......
318i Touring
poolnoodle
Post Wed Aug 18, 2010 12:21 pm
I want to sound proof my 2002 - is dynamat worth the cost. It is a fair bit more that similar other brands but is recommended by the legendary Chip Foose :cool: :roll:
toby
Post Wed Aug 18, 2010 12:48 pm
BMW do their own soundproofing apparently - cheaper?
rp2
Post Fri Sep 03, 2010 1:33 pm
if you do go downt the dynamat route buy the dynamat extreme stuff like seen in the picture above by mr cool.
there are 2 types, the standard cheaper type which has no aluminium backing and the extreme with the aluminium backing. i found the standard dynamat started falling off after a few months so i had a pile of soundproofing inside my doors that rattled about. i bought the extreme stuff to replace it and it lasted 2 years with no issue and is still stuck solid but it does cost a fair bit.
1989 dolphin grey 325i mtec II
