Amp Earth Point
Kemix
Where is the best place to earth an amplifier on an e30? I don't want to drill into boot floor etc. Thanks
eko
- Old timer
Think im right in saying the shorter the earth lead the better?
If thats the case depends where you have put it?
Kemix
im installing amp and components tommorow... amp will be in the boot
JWaller360
I've got an amp mounted on the side of my sub, a short earth lead runs up the boot mounting bracket and fixes to one of the bolts holding the bootlid on, looks tidy!
Kemix
sounds like a good idea mate, I don't suppose you have a picture of this so I can copy you!?
320iAN
i used a rear set belt anchoring bolt for earthing my amp
Kemix
did you have to sand anything down to get bare metal? and did you treat it?
320iAN
the bolt & threads were clean so the earth contact should be 100% i just loosened the bolt off and slid the spade connection in place and tightened it back down, no prob's and i'm using 6mm earth wire.
Kemix
