I'm a little confused how to install these speakers.
Do I have to join the woofer and tweeter wires up to a speaker cable?
http://www.hertzaudiovideo.com/file/pdf ... manual.pdf
Hertz component speaker install help
my internet is going so slow and i cant be botherd to wait for the link to open
however, i'am guessing you have a set of crossovers for the speakers? in this case you connect the tweeter and woofer to the crossover and then the speaker wire in to the speaker wire in on the crossover
This is what it looks like. They both have their separate crossover.
fowler
- Boost Junkie
blitz i can install them for you if you like over the weekend ??
EX A-Tech Workshop bitch !!!
gone but not forgotten
Really? That would be great. I wanted to connect them with my other rear speakers my new 4 channel amp. I've already run the power cable, remote, and ground cable in.
fowler
- Boost Junkie
right i am poss free Sat should take me no more than 2 hours if you could remove the center console section and rear seat will haelp no end and speed up the process.
give me a tinkle in the number in my sig
Ben
just sort me out some beer money
Ben
if they both have seperate crossovers then all you need to do is connect each one to the rear speaker outputs from your stereo
