12" sub recommendation
Justin325i
Evening all,
Looking to replace my 12" sub. It's connected to a Kenwood and an Alpine amp.
Any recommendations would be much appreciated.
Thanks.
Thanks.
'93 E30 325i Calypso Cab
pac1982
How come you have two amps powering one sub? not heard of that one before, i would say get an Alpine Type R, for the money no other sub comes close.
I've recently upgraded from a 12" Vibe sub to a Alpine Type R and its such a step up
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Justin325i
To be honest I don't know.
This is the set up when I bought the car and I haven't changed anything, a kenwood headunit, an alpine amp under the passenger seat and a 12" sub (don't know the make) hooked up to a kenwood amp in the boot.
The car also has a dash mounted TV unit with a video player in the boot so I suspect that one of the amps (possibly the alpine) is hooked up to that and the kenwood hooked up to the sub.
Raj_p
You've probably got a 4ch amp running the speakers and a 2ch/mono running the sub.
As pac said, the typeR subs are awesome. but you need a very good amp to run it.
A sub reccomendation depends on your budget and what you want from it, as in, do you want bass that will rattle your brain or just a nice little kick?
If the later, then you can get subs from £30 at 400w rms which would fullfil your needs.
HTH
Raj
HTH
Raj
Only real men get it done with an M20
Justin325i
This is the amp I have in the boot...not my picture though.
And this is the alpine one...
http://i734.photobucket.com/albums/ww34 ... G_3487.jpg
stup86
I have a kicker 12" that I've been meaning to advertise. May be of interest to you!
Parts needed:
M40/M20 ignition coil with high voltage lead
Justin325i
Thanks, but i'm looking for a round sub to fit the sub box that I already have.
pac1982
No offence but they are both quite puny amps, ideally you need a decent mono block amp to power a decent sub, so if you want to use those amps i would be looking at subs for under £100 as anything better would not used to its full potential without better ampsJustin325i wrote:This is the amp I have in the boot...not my picture though.
GemE30
I've got a kenwood comp sub which is pretty good, does the trick
Justin325i
None taken. As I said this was the set up when I bought the car and I haven't made any changes thus far.No offence but they are both quite puny amps, ideally you need a decent mono block amp to power a decent sub, so if you want to use those amps i would be looking at subs for under £100 as anything better would not used to its full potential without better amps
So what sort of amp would be suited to the Type R? Or should I just go for something like a Type S sub?
kam325itouring
The square l5 you can make your box into a square hole, or go for a rockford P1 or a diamond D1 thats in ure budget and would run off your amp fine.
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
Justin325i
Anyone have any experience of a Hertz DS300 sub??
pac1982
The Alpine MRD M605 is ideal for powering a type R sub, unfortunately these amps are no longer available to buy new but they are practically indestructible so don’t have any worry’s about buying a used one from evil bay.Justin325i wrote:None taken. As I said this was the set up when I bought the car and I haven't made any changes thus far.No offence but they are both quite puny amps, ideally you need a decent mono block amp to power a decent sub, so if you want to use those amps i would be looking at subs for under £100 as anything better would not used to its full potential without better amps
I also use an Alpine MRV F450 5 channel slab amp to power my speakers which is a really nice high end amp that gives a really warm feel to your speakers.
I would really recommend a type R sub as a lot of 12 inch subs struggle to put out a nice punchy bass and are more suited to really loud and low bass notes but the type r is a really good all rounder which sounds nice when you have your system on low added a subtle hint of bass but also is capable of dropping really big bass notes and making your whole car shake.
The best way to spot a good sub is to check the size of the magnet out and the one on the above sub does look a little on the small size, plus it looks like it may be a paper cone sub which is never a good thing, but in all honesty I’ve never heard of the so it could be a really good sub.Justin325i wrote:Anyone have any experience of a Hertz DS300 sub??
Heres a few pics of my system note the size of the magnet on the type R, I’m also running both the amps I recommended above, it looks a bit of a mess at the moment as it needs a good clean and the false floor is not sitting right as I’m currently having my spare wheel re painted
Alpine MRD 605
Alpine MRV F450
E30_Crazy
If you want a good price for straight up ground shaking bass, go Power Acoustik. Most 12" subs run a max output of 1200w, but PA 12"'s run 2400w max, with around 1000w rms. Like said before, you need a good amp to push this power out. I have a 15" PA, running I think 2750w max/1800w rms with an 1800w amp wired up with a 1.5 farad capacitor. I even blew one of the voice coils, and running off one coil, my boot lid, rear fenders, and rear face all "wave" with the bass. Not just vibrate, but has that wavy motion going on.
kam325itouring
why does everyone jump on the wattage bandwagon???? You do know bigger the wattage the bigger the amp more money!! also most of the best branded stuff dont have ten million watts of music power!!!
Kos
JL 1000/1V2 running 2 10w3's in JL HO box was the best "out the box" bass i have ever had
still got the set up and be installing it into the e24 some time
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
pac1982
Very true, the wattage on my Alpine system aint that high to be honest but it would piss on any of the cheap stuff you see with 1 million mega watts printed on the side.kam325itouring wrote:why does everyone jump on the wattage bandwagon???? You do know bigger the wattage the bigger the amp more money!! also most of the best branded stuff dont have ten million watts of music power!!!
Thats another point stay away from cheap amps i would rather buy a used decent amp than a new cheap amp
kam325itouring
a good place to find decent second hand amps is talk audio forums...pac1982 wrote:Very true, the wattage on my Alpine system aint that high to be honest but it would pee pee on any of the cheap stuff you see with 1 million mega watts printed on the side.kam325itouring wrote:why does everyone jump on the wattage bandwagon???? You do know bigger the wattage the bigger the amp more money!! also most of the best branded stuff dont have ten million watts of music power!!!
E30_Crazy
Wasn't trying to the OP to jump on the wattage bandwaggon. Just stating that the best (key work:) quality, while getting awesome bang-for-your-buck, is the Power Acoustik setups.
BadDave
Best quality would be some proper old skool Rockford/Phoenix Gold/Hifonics/PPI amps.E30_Crazy wrote:Wasn't trying to the OP to jump on the wattage bandwaggon. Just stating that the best (key work:) quality, while getting awesome bang-for-your-buck, is the Power Acoustik setups.
They don't have "Bullshit" power ratings and were made with quality in mind,using top notch components, and not built for minimum £££ and max profit.
E30_Crazy
Man, some good 'ol pheonix gold bits of equipment sounds really good to me!... Just finding the good condition, high quality stuff anymore nowadays is nearly impossible. All the pro's and the collectors have already snatched up most of what remains...
BadDave
Getting back OT, I'd be looking for a sub by JL,Rockford,Cerwin Vega.
The spec of the amp suggest 2x100w rms@4 ohm or 300w rms @4 ohm bridged.(Kenwood site)
If you intend on keepng to just 1 sub, then you'd be looking for a sub which handles 300W rms and 600W peak.
