Has anyone fitted 16 x 9 " wheels to an e30?
If so, what kind of offset do I need?
Thanks, phil
16 X 9"
egk2
et15
2.8L M20 Stroker
philn
Cool, did the arches need much 'adjusting'?
egk2
I forgot to mention you need at least a 5mm spacer in the frontphiln wrote:Cool, did the arches need much 'adjusting'?
to clear the struts, I run a 10mm out back to equal out the front and rear
track, I rolled my rear fenders prior to running the 16x9's, I have no rubbing problems whatsoever.
2.8L M20 Stroker
