FOGLIGHT INSTALLATION HELP!!!
Finto_316
Post Thu Jun 10, 2010 10:17 pm
hello,
ive just install `tech 2`foglights into my e30 316i
ive connected all the wires
including the foglight switch..
ive installed 7.5 A fuses into slot 29,30 in the fuse box
ive also installed a `12v 4 prong diode` in slot k8 in the fusebox
i blew the fuse in k8
i bought a new 1 and it didnt blow
after all this the foglights still dont work
any help plz?
BMW e30 325i Sport-88-Diamond Shwartz
Royalratch
Post Thu Jun 10, 2010 10:30 pm
You mean you blew the relay in K8 or the fuse in 29/30?
Did you check the bulbs? Check for voltage at the plugs to the foglamps?
Finto_316
Post Thu Jun 10, 2010 11:45 pm
i blew the relay?
but i got a new 1
emm i checked the power to the switch
and the rear fogs work and show up on d clocks working
but the front fogs dont?
theres no power getting to the switch i tink??
i might just wire them off the dip lights?
is this possible??
Raj_p
Post Thu Jun 10, 2010 11:58 pm
You need to trace the wiring and see where the flaw is, you may have a breakage somewhere
Only real men get it done with an M20
Finto_316
Post Fri Jun 11, 2010 12:03 am
is it hard to trace it into the car?:)
