Amp power cable
afcbob
Post Wed Jun 02, 2010 6:31 pm
Hi where is the best place to running the power cable from the engine bay in to the car.
BadDave
Post Wed Jun 02, 2010 10:27 pm
I'd say, through the bulkhead grommet,and down the drivers side inner sill.
You can feed 4guage through there with minimal hassle.
It should be a similar route to the battery relocation cable IIRC
toby
Post Mon Jun 07, 2010 9:28 pm
The grommet in the bulkhead used for the headlamp 'aim control' pipes, behind the battery, looks ideal. I'm going to try to running a cable through there as I've moved my amp and want to shuffle the wiring around.
