advice/tips on fitting tin top mtech 2 side skirts on cabby?
blacksoul
Post Fri Sep 09, 2005 11:43 pm
hi guys looking for advice on making these fit. they are on at the sides but are not flush with the side panels and are also sagging under the car. if anyone can help i would be greatfull cheers martin.
tourer-dan
Post Fri Sep 09, 2005 11:49 pm
have you drilled the clamps onto the sill?
There's one row of clips which are held onto the sill with 'expanding rivets' and another row of push on clamps which literally clamp the bottom edge to the lip on the bottom of the sill. (a bit hard to explain it all)
BMW sell a 'drilling rig' for all the holes you need to drill for the kit, but I'd hate to know the price, I think it comes to about Ԛ£25 (and that just tells you where to drill holes!)
beardymat
Post Sat Sep 10, 2005 12:05 am
the sills on a cabby are deeper than a tin top due to the extra stiffening,therefore tintop sills dont fit a cabby properly im afraid
blacksoul
Post Sat Sep 10, 2005 12:44 am
yeah cheers guys i know its hard to explane what you mean but i get what your saying my brother has a sport and his kit was factory fitted and i know the problem with the skirts not being wide enough for under the car, i was just wondering if anyone has made these skirts fit as the clips to hold these skirts to the cab aint going to reach. if anyone has done this with sucsess please share your info. and if not it looks like im reaching back into the old pocket:( thanx again martin
moutraklas
Post Mon Sep 12, 2005 11:45 am
guys, i m having the same problem... (see: M tech 2 installation thread). Ok, lets say we find the proper skirts for cabs, then the drilling jigs are the same with ones for saloons? I say that because in ETK i cant find this item for cabs!!!
woodysjw
Post Mon Sep 12, 2005 6:49 pm
You can make them fit I just did this,
the bottom part of the skirt wont reach the lip it just hangs down so best just cut this off, the clips that hold the top of the skirt to the sill are different for a cab to a hard top so get propper cab ones.
then at the ends you will see slits so they can open up you need to make these a bit longer and wider
796 - 1989 Motorsport Edition
moutraklas
Post Tue Sep 13, 2005 12:22 pm
woodysjw wrote:You can make them fit I just did this,
could you be more specific? give more details?
1. in order to install the clips that hold the top of the skirt to the sill, you need to drill? i think yes, tha holes that the car allready has to hold the trim are not enough. You had a driling jig to make the holes?
2. what you mean by "then at the ends you will see slits so they can open up you need to make these a bit longer and wider"
3. you dont hold it at all at the bottom part? (at the lip of the sill i mean)
4. as it can not move right up (because the sill makes a curve until the lip at the bottom) you have put it a bit out than it should be?
5. have a pic to see how it looks???
moutraklas
Post Fri Sep 16, 2005 1:54 pm
SOMEBODY PLEASSSEEEE :cry:
woodysjw
Post Fri Sep 23, 2005 10:45 pm
where the skirt meets the sill at the top you need to get proper Convertible clips otherwise it wont fit. Buy them from BM.
then the bottom of the skirt that should meet the metal lip of the sil wont meet so just get the grinder out and cut it off other wise it will just look crap. the where the ends of the skirt sits in the arches at the front and back look under the skirt here u will see a cut out. this needs to be extended buy about an inch to allow the sideskirt to fit more under the car.
thats it
