Flared Arches
gadjit
Boost Junkie
Post Sat Apr 17, 2010 10:48 pm
Hi
I am looking to flare my arches to accept tyre sizes of 235 front and and 265 rear, can anyone help with where to get arches from that will accept these tyre sizes,i shall also be running 17 inch wheels,
Thanks in advance
Gadjit
koh
Post Sun Apr 18, 2010 10:42 am
depending where you are i would say archenemy would be the best choice
gadjit
Boost Junkie
Post Sun Apr 18, 2010 6:20 pm
Hi Koh
I am in Nottingham, just checked out there website, shall bear them in mind
Thanks Pal
Gary
bootyman
Post Mon Apr 19, 2010 8:12 am
gadjit wrote:Hi
Thanks in advance
Gadjit
What width rims are you running to want to use such tyre size. I run 18 x 13 on the back of my car and only use 265 and that is with a wide arch kit. If you are running anything wider than a 10" wide rims you will have to have the arches chopped and flared properly because rolling them will just look all crumples after a certain point.
Also be careful of Archenemy. Thy franchise their work so you can get some muppet tuning up to mess up your arches. I've seen great work by them and i've also seen shocking work by them and like i said that's due to the fact their name if franchised so anyone can buy into it and start rolling or should i say fcuking up arches with no experience.
