right ive just got my hands on a the fitting kit for rear headrests & i've been through the wiki but all i can find is the guide for fitting them to a touring,
http://www.e30zone.net/e30zonewiki/inde ... _Headrests
now what i want to know is will it be the same procedure to fit them in my sport? probably a daft question but i thought i'd ask.
also will the rear headrest fitting kit for a e36 do the job aswell? i've been offered that aswell if i want it.
rear headrest fitting guide
steve_k
steve_k
back to the top.
steve_k
bump bump goes the thread.
It is the same procedure, i used the same guide when i fitted RHR to my cabby.
The cut-out for the brackets should already be in the seat foam. It's just a case of lining up the holes and then cutting a little slit in the leather/cloth for the headrests poles to go through.
HTH
HTH
steve_k
cheers imy
i'll gice it go in the next few days.
i take it the fitting kit you used was from a e36 (touring?) aswell?
No i used a e30 fitting kit, the touring kit has a few extra pieces i think.
Is it for your Sport?
steve_k
yeah it's for the sport.
i take it the basic part of the kit is the same?
i did a trial run of the headrests in the back of the touring & they fitted that's why i thought about using it.
let's put it this way free is better than £30 lol.
Yeah the basic parts are the same, it should fit
Makes a big improvement IMO
steve_k
finger's crossedImysE30 wrote:
Yeah the basic parts are the same, it should fit15-20 min job if that.
only reason i decided to go for it was because i'd seen a few sports on hear with them & thought "sod it let's do it".
It'll look good
Just be careful when your cutting the holes for the poles to double check that they line up correctly.
steve_k
i'll get my mum's B/F to do it as his hands are a bit more steady than mine lol.ImysE30 wrote:It'll look good
