Just wondering what the pro's and con's are on the 5 stud conversion.
Also what do I need.
Converting to 5 stud. Pro's and Con's
mykez69
gazm3
Simples, proper Bm's have 5 stud.
Source a compact that being broken
mykez69
Lol.
I'm guessing it opens my wheel options up a little up?
Is a different offset on wheels needed at all?
jmc330i
If you use the E30 M3 stuff (if you can find any), it costs a lot, but you will get a setup designed for the E30. You will need wheels with or around the M3 offset.
If you go the E36/compact route, you need wheels of the E36 offset and, by the time you have bought all the bits needed to realign the front wheels etc it will cost almost as much as an E30 M3 setup, but still not have totally the correct geometry. I doubt this would matter for an everyday cruising car, but I reckon it might make a difference once driven hard, especially on a track.
From a cost point of view, its not really worth doing just to fit a set of wheels.
Proper BMs have 1 stud...gazm3 wrote:Simples, proper Bm's have 5 stud.![]()
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
- E30 Zone Meets/Events Team
LOLgazm3 wrote:Simples, proper Bm's have 5 stud.![]()
gazm3
Im so wrongjmc330i wrote:If you use the E30 M3 stuff (if you can find any), it costs a lot, but you will get a setup designed for the E30. You will need wheels with or around the M3 offset.
FMH
I've done around 8 of my own and mates previous/current e30's.mykez69 wrote:Just wondering what the pro's and con's are on the 5 stud conversion.
You'l have bigger/better brakes, wider choice of wheels at a cheaper rate, wider stance 12mm each corner, and not forgetting a extra stud holding the wheel, LOL.
I've got everything you need, let me know if you are interested, avoid all the running around, collecting bits.
Reflex
Hi mate, i'm interested, how much are we talking for the conversion?FMH wrote:I've done around 8 of my own and mates previous/current e30's.mykez69 wrote:Just wondering what the pro's and con's are on the 5 stud conversion.
You'l have bigger/better brakes, wider choice of wheels at a cheaper rate, wider stance 12mm each corner, and not forgetting a extra stud holding the wheel, LOL.![]()
There Was A Time Last Year When I Was 17, But I'm 19 Now... And Things Have Changed
http://photos-h.ak.fbcdn.net/photos-ak- ... 778999.jpg
FMH
Make me an offer
leeparkes
What is the parts list for a 5 stud set up?
I know its Compact ti rear beam (complete)
But about the front, do they 'have' to be E36 M3 items?
FMH
e30 m3 front struts
e30 top mounts
e30 springs
e36 m3 evo hubs
e36 m3 evo wishbones
e36 m3 evo calipers/discs
e30 m3 offset lolly bushes
e30 top mounts
e30 springs
e36 m3 evo hubs
