Anyways, the new head unit's display dims in time with the kick beat like power is being sapped from it to power the speakers. Happens only at medium to high volumes - down low the display is fine and consistent in brightness. Car only has two speakers to the front footwells, i would assume these are standard but will check this weekend.
Head unit is ok as it's one i pulled out of another car and i haven't had any issue with it prior to fitting it to the E30??
What do i need to do, upgrade wiring or fuse or something else
