What offset?
jakkerd
Post Fri Dec 18, 2009 10:25 am
This has probably been asked a 1000 times, but the search gives somany hits it would take ages to find what i need.
Size in the front would be 15x7 and 15x7,5 (or x8) in the rear.
I don't want any archwork done and i'm aiming for a 40-30ish lowering.
What kind of offset would i be aiming for?
Ziggy
Post Fri Dec 18, 2009 10:35 am
Somewhere around ET20 - ET25. ET24 would be stock on the front, but you might need to go lower on the back depending on what width you choose - my 7.5s are ET20 for example.
jakkerd
Post Mon Dec 21, 2009 6:50 pm
Thanks.
kam325itouring
Post Wed Dec 23, 2009 9:05 pm
ziggy how much clearance you got on the 7.5s?? im thinking on putting 8.5s et21 17" dunno if it will clear or not!!
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
jenad
Post Wed Jan 20, 2010 1:41 am
Typical offset is 13 at the front for the 8,5x17. Spacers would be recommended in this case. The 21 will surely fit at the rear, but should be brought at least to the same offset as at the front.
Depending on wheel size, fenders should be at least rolled...
kam325itouring
Post Wed Jan 20, 2010 10:43 pm
jenad wrote:Typical offset is 13 at the front for the 8,5x17. Spacers would be recommended in this case. The 21 will surely fit at the rear, but should be brought at least to the same offset as at the front.
well got the rims on the 8.5s went on a treat!!! and im quite impessed on how it looks, check out my thread in the photo gallery.
kam
