how are subs wired in
no2lurch
Post Sun Nov 22, 2009 10:31 pm
i'm new to this ice lark, so how are subs wired in?
do they need a power source etc?
Post Sun Nov 22, 2009 10:33 pm
Subs are connected to an amp, amp is connected to battery and headunit.
Sub get's it power from the amp.
HTH
no2lurch
Post Wed Nov 25, 2009 1:27 pm
ok thanks. i have an small amp running the two 6x9 speakers in the rear of my touring, so can i use this amp?
Post Wed Nov 25, 2009 3:44 pm
If your not too fussed with massive bass/power, then it should work okay.
Assuming you are going to run the sub from the amp only, not the speakers as well :?:
