Hi,
I've got me a set of headrests and plastic rings for my touring, my question is how do you know where to make the holes? Am i right in thinking touring rear benches already have the internal bits fitted as standard?
so its just a case of making holes? but where exactly?
thanks, Andy.
touring rear headrests
All explained in the article below:
http://www.e30zone.net/e30zonewiki/inde ... _Headrests
Use a screwdriver or similar to poke up and you will then be able to feel where you should make the hole
ac248
Nice one, thanks v. much, thats exactly what i needed to know.
I used the same link/method
Good luck
Good luck
TPS
Those white washers are a right pain to locate & fix in the channel of the seat.
ac248
Yup looks like it could be a bit fiddly, i've cut the holes but then it got too dark - damn winter - i'll post some pics up when i'm done. Thanks for all the advice.
ac248
UPDATE: Thanks guys all done, heres the result!
Looks much better
GC318
Nice job, well done. Always think tourings look much better with rear headrests
