lowering springs
fiky
Post Fri Sep 04, 2009 11:39 am
hi guys can you tell me what drop can i put on my e3o,i dont want it to low at the front :roll: :roll: :roll:
Post Fri Sep 04, 2009 12:51 pm
You can put a drop of 15mm upto 80mm on a E30 :)
poolnoodle
Post Sun Sep 13, 2009 1:23 am
A drop of 30/40mm is typically a suitable drop for road use. Springs such as Eibach Pro Kit are in this range and work particularly well in appearance and handling. Any more than this and you will need to alter the shocks as well and may have issue with speed humps and tyre scrub. It depends a lot on what you are after in the way of looks and performance
Morat
Post Wed Sep 23, 2009 12:22 pm
60/40 is regarded as the maximum practical drop, but can still end in tears on speedbumps. Mine is on the Eibach kit which is 35-40mm all round. It really depends if you are aiming for looks or handling.
