Alpine CDA7876RB Headunit
Vibe Slick S12
Ӣ Speaker Size: 12"(323mm)
Ӣ RMS Power: 400w
Ӣ Peak Power: 1200w
Ӣ Sensitivity: 90dB
Ӣ Frequency Response: 20-1500hz
Ӣ Impedance: 4ohm
Alpine MRD M605 Mono Block Amp
Ӣ Mono subwoofer car amplifier
Ӣ 300 watts x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
Ӣ Internal, variable-speed cooling fan
Ӣ MOSFET power supply and output stages
Ӣ STAR Topology for cleaner sound
”¢ Bass Engine® features:
- Low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
- Selectable subsonic filter (off, 15Hz, or 30 Hz)
- Parametric EQ variable from 30-160 Hz, ±12 dB
- Bass Compensator enhances low-end definition
Ӣ Preamp outputs
Ӣ Time correction 0-10 milliseconds in 0.1ms steps
Ӣ Phase adjustment 0-180
Now where the help comes in, although I’m very good at fitting audio the art of fine tuning it is a mystery to me, my main point of confusion is the setting on the amp, I understand how to use the gain settings but the other settings I really don’t have a clue about they are as follows”¦”¦
LP Filter 30-200HZ
LP Slope 12db ”“ 24db
Subsonic Filter Off ”“ 15hz ”“ 70hz
There is also a setting via the digital menu for Bass EQ db which I assume is a kinda decibel booster which goes from 0 - +16db
Heres a picture of the dials and switches”¦..
If someone can explain the above to me it will help me no end in setting up the system, my head unit also has built in high and low crossovers but at the moment there turned off.
If you need and more info in order to help me out please ask
Thanks in advance for any help given
