Some easy coilover advice... for stance.
Orrin
Post Mon Aug 10, 2009 5:09 pm
Hiya guys,
Looking for a set of coilovers for a 320i. They will be used for stance and stance only, car will hardly be driven if I'm honest. I used some hot-tuning one's on my Mk3 Golf last time round and it sat like this...
I'm going to go for a similar stance on the 320, if I can or if it's even possible.
I've probably got about £700 to play with and want them ASAP.
What issues will I come across with camber? positive or negative, to be honest I'll probably feed it some negative anyway but of course, too much is a killer.
Any help is massively appreciated. Already used the search too but found nothing I wanted to hear.
Thanks, Orrin.
FormerMember
Post Tue Aug 11, 2009 10:25 am
Sure it's possible to get the car sit LOW, especially if it won't be driven much.
Lowering the car will increase camber and toe-in both in the front and in the rear, but especially in the rear.
Biggest problem will be the front axle, because when you lower the car a lot the tires will hit:
a) wheel arches
b) body
c) strut tower
and also the geometry will be totally fucked up to be honest :)
But, if it's more like "all show, no go" car then there isn't a problem.
Here's pic of my cabrio, 285mm from rim center to wheel arch in front and in the rear. Daily driven in the summer..
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
JimmyC
Post Tue Aug 11, 2009 10:36 am
If you're lowering it you will add some negative anway and toe, if you wish to add more/less camber at the front then you will need adjustable front topmounts.
I'd highly recommend getting the cars geo done after fitting
As I mentioned on another thread, I will have a new kit designed towards road/trackday cars to go alongside full race avaliable at the end of the week. I'll also be offering rose jointed topmounts front and rear.
Will be doing a tasty launch promo for the zone too ;)
Must kick my partner on the trader status today!
miniblob
Post Tue Aug 11, 2009 11:51 am
Sorry to go off topic, but that cabby looks awesome!!!!!!!
327 Touring with bass!!!
Orrin
Post Tue Aug 11, 2009 8:15 pm
miniblob wrote:Sorry to go off topic, but that cabby looks awesome!!!!!!!
Hey no worries, I completely agree!
Jimmy, I will keep my eyes peeled for your deals then ;)
Also what's the crack with this 45mm & 51mm strut? I'm assuming it's going to be better for me to upgrade to a 51mm strut? Assuming again that the ones on my car are a 45, I'll have to check when I pick it up tomorrow!
It's a 1984 320i if anyone can save me the hassle of having to check :)
Jonsku, you have a PM :)
d6dph
Post Tue Aug 11, 2009 8:29 pm
JimmyC wrote:If you're lowering it you will add some negative anway and toe, if you wish to add more/less camber at the front then you will need adjustable front topmounts.
He contacted me today Jimmy, Just catching up on some zone reading whilst eating my tea then I'll get on with sorting it :)
Orrin
Post Tue Aug 11, 2009 8:40 pm
Could be sooner than I thought then? :D
Post Tue Aug 11, 2009 9:37 pm
You will have 45mm struts :)
Orrin
Post Wed Aug 12, 2009 1:34 am
ImysE30 wrote:You will have 45mm struts :)
Thank you very much :)
Is it worthwhile me upgrading then? Do I just need struts and hubs?
....Wow it's been a while since I was asking questions...
Post Wed Aug 12, 2009 1:37 am
Yes it is worth upgrading, you will probably have rear drums and not discs too.
Why not fit a 2.5 engine in there too whilst your at it? :P
Find/buy a knackered (bodywise) 325 and swap the suspension and engine over 8)
harry_p
Post Sat Aug 15, 2009 1:45 am
most e30 coilovers need a set in exchange to modify, so might be worth keeping your stock stuff on there at the moment and sending some 51mm struts in as the exchange units for your new coilovers.
you can't really get cheap coilovers for the e30 as the front stub axel / hub carrier etc is all welded in one piece to the strut, bit of a pain tbh.
cheers,
harry
croms
Post Wed Aug 19, 2009 10:04 pm
sorry to hijack this thread, but what wheels are those on the white cab? :twisted:
FormerMember
Post Thu Aug 20, 2009 6:59 am
croms wrote:sorry to hijack this thread, but what wheels are those on the white cab? :twisted:
17" BBS RS
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
