Hi guys
I've done some looking around the website and can't find an exact answer.
I've got an electric aerial, it has 3 wires Black, White and Red. The black looks like and earth but what are the other two, perhaps power for up and power for down?
2nd question, I have a power probe, what do I need to power up to test the aerial?
Cheers in advance.
Another Electric Aerial Question
MJJ_ZX6RR
The three wires will be for 12V +ve, Earth and signal from head unit. I would suggest black is earth, red is +ve, white is signal. Signal is blue on my aerial.
Connect red and black to the battery, then try touching white to 12V +ve - should raise the antenna. If this works, then you will need to connect the white to the correct lead from the head unit - a real PITA job unless the wire is already in place.
Martin.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
