Spraying rocker covers... any tips?
Nay
Channel Island Crew
Channel Island Crew
Post Thu Jul 16, 2009 6:10 pm
I'm thinking about spraying up some rocker covers this weekend. Just want a bit of advice.
First step is obviously to clean them. What would be the best stuff to use to eat into the built up crap on them?
Obviously a little sand-down as usual and a nice little primer layer with another little sand down. and so on.
What paints are the the best to use? Primer? Will the engine get so hot that rattle can paint will just fail after a bit of use?
Finally, how would people go about making the lines and logo's a different colour? To make them silver/metal? I assume for the latter, just sand down the paint to the bare metal, start using finer paper, then polish?
I just would like to mock up a few Ideas. See how it goes...
Uni is killing the project.
MJJ_ZX6RR
Post Thu Jul 16, 2009 6:17 pm
Gunk/Degreaser for the muck. No sanding whatsoever, just use a couple of coats of primer. Spent bl00dy ages with a sharp craft knife masking each of the raised stripes/letters before priming and spraying.
I just used normal primer, aerosol paint and clear lacquer. Been fine for a few months, I don't think the rocker cover gets ridiculously hot.
Martin.
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
JimmyC
Post Thu Jul 16, 2009 6:19 pm
clean, prep, prime, paint
Then use a file over the raised bits to take them back to metal
Nay
Channel Island Crew
Channel Island Crew
Post Thu Jul 16, 2009 6:26 pm
JimmyC wrote:clean, prep, prime, paint
Thats what I thought.
I have a few ideas of what to do. Need to get hold of some Diamond Schwartz Metallic rattle can paint! Some satin black (getting for my spoiler any way), some metallic red. And the M'Tec colours.....
Gonna be a fun afternoon!
hongkongfuey
Mad-tango-geezer
Post Thu Jul 16, 2009 7:22 pm
i used plastcote project paint from B&Q, had it on there for a few months now still as bright as ever
with cars like mine,
Post Thu Jul 16, 2009 7:46 pm
Thanks for the tips too :P
fuzzy
He who sleeps with "Gingers"
Post Thu Jul 16, 2009 7:50 pm
i used the candy apple red mettalic spray cans from B+Q. its been on a couple of years and still looks good.
Nay
Channel Island Crew
Channel Island Crew
Post Thu Jul 16, 2009 9:50 pm
fuzzy wrote:i used the candy apple red mettalic spray cans from B+Q. its been on a couple of years and still looks good.
Perfect. But a darker red is needed! :twisted:
hongkongfuey
Mad-tango-geezer
Post Fri Jul 17, 2009 10:00 am
have a look at the plasticote stuff they have all sorts, everything from gold chrome to burgandy velvet effect spray even stone finish
Nay
Channel Island Crew
Channel Island Crew
Post Fri Jul 17, 2009 10:48 am
Awesome, but will probably have to order it online.
DaveD
E30Zone Wiki Specialist
Post Fri Jul 17, 2009 10:54 am
didn't even prime mine as it is powder coated already cleaned thoroughly and just sprayed with 2 pack sanded the logos then lacquered
maf260
Post Fri Jul 17, 2009 11:36 am
Did mine last weekend.
Cleaned thoroughly with Autoglym engine & machine cleaner (great stuff, works on everything), couple of coats of primer (red oxide as I was painting it red) and then used the Plasticote quick drying enamel, again a few coats. Let it dry and then sanded the raised bars and BMW lettering with progressively finer paper. Also cleaned & polished up all of the securing bolts so it now all looks great.
I did this as a result of checking and adjusting the valve clearances - a very worthwhile job I'd recommend to everyone. The car runs a lot better now and is much more responsive.
gareth
Post Fri Jul 17, 2009 3:02 pm
a wire brush attachemtn on a drill will remove the corrision that's probably present. it'll look a lot nicer if you do this.
file the tops of the letters and stripes flat first, then paint. it'll save work once it's painted as they're not very flat and it's a real git if you scratch the paint while spending ages getting the lettering to look good.
to get a nice finish, draw file the raised parts. this means to hold the file in two hands and slide it sideways over the rocker cover, from end to end. it'll make smoother lighter cuts and even the finish out easier. then wrap some emery paper round the file and repeat.
i used el-cheapo primer and cellulose black on mine and it's been fine with the exception of some coolant leaving marks on it when i stupidly left the breather screw loose :(
Nay
Channel Island Crew
Channel Island Crew
Post Fri Jul 17, 2009 3:11 pm
:chuckle: Exactly the thing I'm aiming to do. I'm estimating a 10bhp+ increase and make it more econimical.
Will be having a go this weekend me thinks. Will post up some pics of the results!
Post Fri Jul 17, 2009 3:15 pm
I might be too winkeye
Make sure you take some pic's of each stage :wink:
gareth
Post Fri Jul 17, 2009 3:26 pm
here's mine, before i refitted the head.
Nay
Channel Island Crew
Channel Island Crew
Post Fri Jul 17, 2009 4:42 pm
ImysE30 wrote:I might be too winkeye
Ok, will do!
hongkongfuey
Mad-tango-geezer
Post Sun Jul 19, 2009 9:20 pm
StuBeeDoo
Post Sun Jul 19, 2009 9:29 pm
OMG! My eyes....
You should have warned us we'd need dark glasses. 8O
Post Sun Jul 19, 2009 11:42 pm
hongkongfuey wrote:Image
Now that's :cool: :cool:
Love it :twisted:
Post Sun Jul 19, 2009 11:50 pm
HELP I CAN'T SEE!!!!!!! :cry:
