16x9 e30 Wheel experts needed :)
drifty325i
Post Wed May 20, 2009 11:56 am
Hi Guys,
Ive just ordered 2x more Keskin KT1s et15, I already have them on the back with et10 on a p/fl e30. 225/45/16s
1)With no spacer on the front the rim is touching the strut but it still spins the wheel fairly freely (have not driven it like this only pushed the car) the tire is just touching to JUST
2)if I can get away with a 3mm spacer ill run with that as its on a 9inch rim and there is very little clearance for the guard on the other side. I NEED to keep the offset as high as possible as im running 225/45/16s
3) With 5mm spacers there is plenty of clearance, I no almost everyone goes down this road but im not keen unless i have to, i want the rear fatter than the front
4)How much minimum clearance would you recommend between the strut and the rim/tire?
Riley
oakey
Post Wed May 20, 2009 12:58 pm
Shame, the schnitzers looked so 'right'. Understandably though you need a bit more rubber! Sorry I cant help you with your question though :P
What about on full lock??
drifty325i
Post Thu May 28, 2009 4:11 am
Im still keeping the Schnitzers at this stage :) thanks though.
Any other input on the offsets?
dylek
Post Sun May 31, 2009 4:58 pm
Hi there!
if u change your front strut from 51mm into 45mm (prefacelift one) and run stretched tyre then you should be ok with et 15 and 9j on the front ;)
cheers
FormerMember
Post Mon Jun 01, 2009 11:42 am
drifty325i wrote:4)How much minimum clearance would you recommend between the strut and the rim/tire?
The main problem is with rim, tire will rub itself the space it needs.
I'd say 1,5-2mm is the minimum you've to have between strut and rim. If your front main bearings are old / worn, then they can let the rim touch the strut a bit but it won't do anything else than small marks on the strut so no big worries there.
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
FormerMember
Post Mon Jun 01, 2009 11:44 am
I had 16x9 ET15 rims on my car without spacers and they worked very well if i remember correctly. 3mm spacer should be more than enough, otherwise your arches will be in danger :)
dylek wrote:Hi there!
cheers
Yes, but that's really bad option. No idea whatsoever to put worse dampers & springs to your car.
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
Kit_L
Post Mon Jun 01, 2009 11:55 am
Wouldn't coilovers give you more space?
e30jamin
Post Mon Jun 01, 2009 4:41 pm
looking for a newset of wheels my self as from vw side of things been looking at wheels for mk's and that what et is best for a e30 cab 1989
Post Mon Jun 01, 2009 4:49 pm
Depend's on the alloy width you are going for. 9J is ET15 i believe :)
e30jamin
Post Tue Jun 02, 2009 12:39 am
can you get 7 et 35 on maybe with 10mm spacer ?
Post Tue Jun 02, 2009 12:45 am
I had fitted 17x7.5J alloys fitted and ran a 3mm spacer without any issues :) Ideally you want at least a 10-15mm spacer 8)
e30jamin
Post Tue Jun 02, 2009 12:55 am
cool think i got some 10mm ill try tomo nice one mate :cool:
drifty325i
Post Tue Jun 02, 2009 11:51 am
Awesome thanks for your advice Josku, I'm a massive fan of your car and advice :) I might machine my 5mm ones down to 3mm. Should looks sweet
ill be running 7mm ones in the back so should look fairly even. I have adj camber plates to so that helps
