Making a start on the i.c.e
shedrool83
Post Mon Apr 20, 2009 11:17 pm
Picked this up from a mate tonight.(cheers Gray)
I wont be going for anything special just a cheap as possible set up will do me.
Cut out for sub or subs
compartment for amp
compartment to acess the spare wheel
Very nicely made and will still have space in the boot
Post Mon Apr 20, 2009 11:20 pm
That look's awesome, looks very slick :cool: :cool:
What sub/amp will you be using?
shedrool83
Post Mon Apr 20, 2009 11:39 pm
Havent thought about it yet Imy.
I'll measure up the cut out and then see what i can pick up to fit it.
Post Mon Apr 20, 2009 11:42 pm
Nice pair of 10" subs or even 12".
Where did you get the cut out from? Custome made?
shedrool83
Post Mon Apr 20, 2009 11:59 pm
Yeah mate it's custom made fits perfectly.
Looking at the length of the space for the sub i think your right i'll need two.
Post Tue Apr 21, 2009 12:03 am
Can more be made?
2 is the way forward :P :)
shedrool83
Post Tue Apr 21, 2009 12:13 am
I dont know who made it.iirc it came from a breaker jbh(zoner) had.
I dont see a problem making then using mines as a template.
Post Tue Apr 21, 2009 12:23 am
Not sure it would fit in my cabby though :(
shedrool83
Post Tue Apr 21, 2009 12:29 am
Deffo wont bud.
Post Tue Apr 21, 2009 12:31 am
Bet you already checked, seeing as you've got one also :)
Good luck with finishing it off :thumb:
shedrool83
Post Sat Apr 25, 2009 10:43 pm
Got the amps and sub i need now just need to purchase the wiring and make a wee mod here and there in the boot.
Pretty basic equipment but it will do me.
12" magnat sub and 2x spl x 350w amps.
BadDave
Post Sun Apr 26, 2009 2:47 am
Are you planning on bridging 1amp to power the sub and the other to power some comps in the front Jake?
Gimme a shout if you need it all wired up mate :thumb:
shedrool83
Post Sun Apr 26, 2009 8:02 am
BadDave wrote:Are you planning on bridging 1amp to power the sub and the other to power some comps in the front Jake?
Plan was one amp for the sub and the other for the speakers Dave but i'll talk to you tonight about that if your on.
BadDave
Post Sun Apr 26, 2009 8:53 am
That's fine bud.
Catch me on msn later and I'll talk you through it.
shedrool83
Post Sun Apr 26, 2009 9:00 am
That's fine bud.
Will do mate.
shedrool83
Post Sun Apr 26, 2009 8:01 pm
Made a wee mod to the boot install today so the sub is secure.
Two blocks of wood some old grey boot carpet and a tin of satin black later.(would hate to count up how much i have spent on satin black paint lately LOL )
Not to shabby imo
Post Sun Apr 26, 2009 10:06 pm
Very neat, nice job :cool:
BadDave
Post Sun Apr 26, 2009 10:19 pm
Looks good Jake.
Should be able to hide most of the wiring behind the sub cabinet for a tidy wee install
shedrool83
Post Sun Apr 26, 2009 10:42 pm
BadDave wrote:Looks good Jake.
Yeah there enough of a gap down the back for the wires and i can as use the compartment that the amp was going to go for the fuse or anything else that has to be accessible.
SammySmack
Post Mon May 11, 2009 6:52 pm
looking like a professional job already!
im taking notes...!
good luck for the finish
shedrool83
Post Tue May 12, 2009 8:05 pm
Apart from tidying up the rear speakers wire(never had enough :o:) its finished. :woohoo:
Changed the colour of the boot lining to black to match the rest.
And with the help of baddave its sounding not to bad either.
BadDave
Post Tue May 12, 2009 8:44 pm
Can't take any of the credit TBH
All i did was tweak a setting or 2 and change how the sub was wired up. :D
shedrool83
Post Tue Jun 02, 2009 10:15 pm
Finish the install tonight.
I changed the amps as one wasnt working as it should,so i now have a 350watt kenwood powering the sub and a 300watt spl powering the kenwood 6x9's.
I also upgraded the rca's for quality ones (autoleads and fusion) to replace the cheapo's i got off ebay and fitted a dvd,tv,bluetooth headunit and juice 1.2 farad power cap.
Fuse's and sub crossover hidden under access panel
E30_Jatt
Post Tue Jun 02, 2009 10:34 pm
shedrool83 wrote:Finish the install tonight.
i've got this same headunit and when I test fitted it I found that the screen fouls on the indicator stalk when going upright. I can see that you have put the OBC on the right to solve this and wanted to know is this easy enough to do?
BadDave
Post Tue Jun 02, 2009 10:36 pm
E30_Jatt wrote: i've got this same headunit and when I test fitted it I found that the screen fouls on the indicator stalk when going upright. I can see that you have put the OBC on the right to solve this and wanted to know is this easy enough to do?
All you need is the heater panel from a left hand drive motor
E30_Jatt
Post Tue Jun 02, 2009 10:43 pm
ahh... I see, I thought it was just the case of taking it out and moving to the other side, and if need be modifying the housing slightly.
Well, thanks for that will keep my eye out for a LHD heater panel
shedrool83
Post Tue Jun 02, 2009 10:47 pm
Yip as Dave said get yourself a lhd heater panel.
It isnt hard to change it at all
miniblob
Post Fri Jun 05, 2009 12:25 pm
Yep, I've done the same mod on mine!! Just swap the panel!!
Gonna take the screen out of mine soon, but considering leaving the lhd panel in there with a standard (non-screen) stereo!!
Can't make up my mind if i prefer the position of the h/u or not!! Lol!!
327 Touring with bass!!!
Post Fri Jun 05, 2009 12:27 pm
What headunit have you got fitted?
Looking to get mine done :)
shedrool83
Post Fri Jun 05, 2009 2:15 pm
Post Fri Jun 05, 2009 3:50 pm
Nice bit of kit that 8)
