i was droving home at lunch and the radio just turned off.
radio is a sony explode type.
took the radio out when i got home and the fuse is still ok in the back. checked all the fused in the fuse box and they are ok too. all the wires going into the radio seem fine too.
tried another radio, but nothing.
any ideas guys? are there any fuses etc hidden form view that i need to try?
Radio suddenly stopped working - help
no2lurch
Sawyer_E30
Yay I've got a Sony Xplode to.no2lurch wrote:i was droving home at lunch and the radio just turned off.
Right then fuses. There will be either a 10 or 15 amp fuses in the back of the head unit. But it is more likely to be one under the bonnet.
Fuse12 - 7.5amps should do it.
Also are you using BMW own radio wire, or have you linked it straight from the battery??
E30: The only E-number you should be concerned about
Sawyer_E30
Didn't read that you checked the main culprites - Sorryno2lurch wrote:...the fuse is still ok in the back. checked all the fused in the fuse box and they are ok too. all the wires going into the radio seem fine too.
Must not speed read at lunch!!
no2lurch
it runs through an iso plug off the original wiring
pac1982
I think your E30 has blown your radio up on purpose becuase Sony Xplode's should only be used in cars such as Ford Festa's & Shitron Waxo's and it made your E30 feel cheap
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
slightly off topic, did you get my pm
no2lurch
i did mate. going scrap yard later to see if there are any there. i'll let you know...
Sawyer_E30
He's tested another radio since, and it still doesn't work. Hence...pac1982 wrote:I think your E30 has blown your radio up on purpose becuase Sony Xplode's should only be used in cars such as Ford Festa's & Shitron Waxo's and it made your E30 feel cheap
no2lurch wrote:tried another radio, but nothing.
mrLEE30
did you sort this problem out?
if you did not please let me know if your electric ariel works properly (when the stereo worked ofcourse!!)
sounds like you have no voltage at the head unit power lead.
sweep
Have you checked the wiring plugs behind the glove box?
no2lurch
not checked this. what am i looking for please?sweep wrote:Have you checked the wiring plugs behind the glove box?
mrLEE30
answer my elecric ariel question nd i can help you (i am asking if this works as i assume you dont have a multi meter to use.
mrlee
mrlee
