components up front
rossd
how did people mount the crossover box when fitting components in the front?
was told somewhere near ecu box but only way i can think is tie wraps/stickyback pads?
about to start on this so anyhelp appreciated
Ross.
Ross.
Elecblondie
My crossover is cable tied under the ECU on the driver's side.rossd wrote:how did people mount the crossover box when fitting components in the front?
Ross.
rossd
ive done it
i cable tied drivers side under the ecu and passenger side is tie wrapped down inside glove box
Had to drill couple of holes on the underside
Its done now though
Infinity reference 5010 components in front
Infinity reference 5012 coaxials in rear
Its done now though
robbo86
Where can I buy JUST crossovers. Already have tweeters.
Elecblondie
Crossovers are bespoke to the components being used, so I imagine it would be unusual to buy them separately. You could always make up your own.robbo86 wrote:Where can I buy JUST crossovers. Already have tweeters.
http://www.diyaudioandvideo.com/FAQ/XOver/
secondtimelucky
Or i could make you someElecblondie wrote:Crossovers are bespoke to the components being used, so I imagine it would be unusual to buy them separately. You could always make up your own.robbo86 wrote:Where can I buy JUST crossovers. Already have tweeters.
Wanted: Any old component speakers, complete or separate parts, let me know what you got
robbo86
Infiniti something or overs. I bought them in tweeter pods, presumably I will have to match my fronts to infiniti then
secondtimelucky
Not neccesarily mate, as long as the power is roughly the same and the frequecy response is similarly matched, which most woofers will be, then your finerobbo86 wrote:Infiniti something or overs. I bought them in tweeter pods, presumably I will have to match my fronts to infiniti then
Boyraceruk
Why not mount the crossover on the door?
Elecblondie
It depends where the drivers are, if you've left the woofer in the original location and put tweeters in the standard location you'd have to run two pairs of leads into the door rather than just one.Boyraceruk wrote:Why not mount the crossover on the door?
chisel
I'm doing mine right now, I was gonna run the cable and have them on show in the bot along with the amps and some tify wiring but in the end decided just to tuck them up under the dash. I've got my centre consol out and there;s a plastic pannel looks like the heater whatsit, a bit of velcro and job done, no need to go drilling.
robbo86
In my case I am talking about door mirror tweeters. But yeah, how much would you want to build some crossovers secondtimelucky or would you adivse buying some comps for the front first.
Morat
Is there no room next to the standard speaker location? I thought the car with O/E tweeter pods had crossovers in there....
secondtimelucky
I can probably do some in-line ones for less than a tenner posted, or separate off-board ones for around twenty quid (my pound key is broke btw
pac1982
Where you gonna mount your tweeters??
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
robbo86
If they came as standard I think yes, but mine did not and the original tweeters have long since beeen repaced before I bought them and besides which my question wasnt so much where to put them as where to get them!Morat wrote:Is there no room next to the standard speaker location? I thought the car with O/E tweeter pods had crossovers in there....
