ATTACK the rattle!
Sawyer_E30
Post Tue Apr 07, 2009 2:54 pm
Hello all,
About to fit my old kit back into the car after a de-rusting session last month, but before it goes back in and I make a mess of it instead.
Where are the key locations of most annoying rattles and other vibrations?
Ta.
Also how good is dynamat, and what other stuff would you guys suggest???
E30: The only E-number you should be concerned about
Sawyer_E30
Post Tue Apr 07, 2009 3:07 pm
Also from other forums people have recommended Weather Stripping.
Can this be used??? :?
oakey
Post Tue Apr 07, 2009 4:16 pm
Is this a tech2 kit you are asking about?
Sawyer_E30
Post Tue Apr 07, 2009 4:35 pm
oakey wrote:Is this a tech2 kit you are asking about?
So I didn't specify did I? :?
Mtec 2 stuff is back on already. I was referring to (in my head) my amp and subwoofer.
swllt
Post Tue Apr 07, 2009 4:41 pm
I did a complete sound proofing of my 320i
Used black bitumen sound proof pads from Ebay (3 packs) and 100mm wide weather sealing tape from B & Q (2 rolls)
Best done in warm weather and wash down panels with thiners first.
Stick the stuff everywhere and seal any holes in the bulkhead (scutle)to the engine bay.
Back of back seat really helps as does covers over petrol pump under seat
Spray inside doors with underseal.
Put in extra foam or underlay under carpets and seats
Pads behind standard speakers help
Now put back all the trim and listen to --- nothing!
(Until you hit 4500 RPM then bliss)
the extra weight is next to bugger all and its well worth it if you have the interior out
Sawyer_E30
Post Tue Apr 07, 2009 4:44 pm
swllt wrote:I did a complete sound proofing of my 320i
Just what I was after!
Thanks mate :thumb:
