red needles in speedo cluster
dilo_attax
Post Fri Apr 03, 2009 4:56 pm
want to red my needles, anywher i can purchase any?
GrindCulture
Post Fri Apr 03, 2009 4:58 pm
I've seen some with early Audi A4 needles, they look pretty cool if you can get hold of some.
Not in E30s any more :(
georob
Post Fri Apr 03, 2009 4:59 pm
Red pin stripe works well winkeye
E34 x 1 - V8 + lots of CF
E30 x 2 - Tourings (1 x M50, 1 x M40)
RS6 C5 - Stage 1 remap - 500bhp
George
Post Fri Apr 03, 2009 5:02 pm
Take the needles off and put a coat of red nail varnish on them winkeye
georob
Post Fri Apr 03, 2009 5:07 pm
Pin stripes save's run marks etc though :P
George
dilo_attax
Post Fri Apr 03, 2009 5:12 pm
georob wrote:Red pin stripe works well winkeye
wil just try that, anywher on the forum how to take dails out and glass? thanks :mad:
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Fri Apr 03, 2009 5:23 pm
You don't need to remove the glass - everything comes out from the back of the cluster. Once you remove the cluster from the dash you will see the fixing screws (from memory they are small star head screws) that hold on the rear cover. Remove these and the entire cluster comes away from the housing. A wee tip - once you've got it apart don't touch any of the surfaces of the gauges with bare fingers - use latex gloves. Avoids seeing greasy fingerprints inside the cluster once it's all back together. :mad:
Taylor.
dilo_attax
Post Fri Apr 03, 2009 5:26 pm
nice one taylor
Post Fri Apr 03, 2009 5:27 pm
Can you take the cluster out without removing the whole dash?
georob
Post Fri Apr 03, 2009 5:29 pm
Yes, remove two top screws, remove panel in front of steering cowling, knurled nut behind dash, remove 3 or 4 screws along bottom of cluster, pull et voila.
George
Post Fri Apr 03, 2009 5:34 pm
Thank's :thumb:
StuBeeDoo
Post Fri Apr 03, 2009 7:55 pm
I've done red needles twice and both times I've used a marker pen. :D
You need the chisel-tip one.
HTH
Stuart.
jbh
Hartge Crew
Post Fri Apr 03, 2009 7:57 pm
StuBeeDoo wrote:I've done red needles twice and both times I've used a marker pen. :D
HTH
Stuart.
+1 thats how mines were done :wink:
Post Fri Apr 03, 2009 7:58 pm
Will it not fade away though?
Ziggy
Post Fri Apr 03, 2009 8:15 pm
Tin of red humbrol works well & hasn't faded in the couple of years mine have been done...
Daryll
Post Fri Apr 03, 2009 8:16 pm
Ziggy wrote:Tin of red humbrol works well & hasn't faded in the couple of years mine have been done...
+1 did mine in the same way and they're still fine. 8)
@e30_daryll
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Apr 04, 2009 12:33 pm
check out my dial painting link
[url]http://www.e30zone.net/modules.php?name ... ight=dials]/url]
m_jermyn
Post Sat Apr 04, 2009 12:56 pm
Try this out mate a very very handy post.
http://www.e30tech.com/forum/showthread.php?t=51635
Mike
