LHD heater panel doesn't fit...
aceraf
Post Sun Jan 25, 2009 3:07 pm
I purchased a LHD heater panel to enable me to install my motorised DVD player into my 4door without having to cut the indicator stalk (have OBC), but it doesn't seem to fit.
There are quite a few little things that stop it from fitting.
Also the wiring for the OBC seems wrapped up too tight, and there is a single blue wire going from the OBC loom towards the glovebox, and this will be in the way of where the head-unit would go!
Just spent a few hours removing the normal one and trying to fit the new one, but gave up and put the original back in now.
Has anyone actually been able to get this fitted, and if so any pics, and tips on how you made it work?
[/youtube]
Breaking 325i Touring
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sun Jan 25, 2009 3:15 pm
this has been done loads buddy
The blue wire for the obc i believe goes to the indercator stalk just unplug th eobc loom and loosen it off its only cable tied style into the dash
Id imagine its a time consuming job but dont give in
**BANNED**
Post Sun Jan 25, 2009 3:27 pm
Heater control panel is the same size LHD/RHD so will fit into the dash mount.The OBC unit,as it is moved several inches to the right may well need it's loom adapting to fit.Just be a matter of unwrapping the loom a little to give the wires a bit more freedom....or even splicing in a little more cable.
Youth is wasted on the young.
eko
Old timer
Post Sun Jan 25, 2009 5:44 pm
I fitted a LHD panel in Benjys touring.
No OBC in his car but as above just loosen the OBC loom to gain some slack,we had to extend the anologue clock wires on his.
Only other thing was the holes for the top screws(the tiny ones) didnt line up but just screw them in to create new ones.
Job done :D
