They same way as if we travel abroad on holidays you are meant to stick reflectors on your headlights, hope someone understands what I mean!
German smoked hellas
C2HEG
If you buy smoked hellas from Germany, do you need to change the direction the light is projected as they drive on the right side of the road?
maxfield
Yes, I would certainly assume you do.
stonesie
And it takes seconds to do without any stick-on crap
Edit
http://www.e30zone.net/modules.php?name ... t=headlamp
Edit
snitzl
you only have to turn the reflector of the low beam about some degree. the reflector will be removed with 3 screws.
iDreamBeemer
Where are you looking? Found some cheapish ones you'd care to share?
