Spraying an IS lip
RevBillyG
Post Thu Jun 30, 2005 7:59 am
I've just got myself an IS lip for the old banger and will need to spray it a more appropriate colour.
Now, the spoiler itslef is quite flexible so I need a paint that won't crack should the spoiler flex. I'm guessing that vinyl dye (with an appropriate basecoat) from Halfrauds will do it.
Any other recommendations or tips?
Best smiley ever-----> winkeye
smithy318i
Post Thu Jun 30, 2005 9:21 am
Plastic primer and normal paint from halfrauds!
I used normal primer, and the paint is starting to flake off :cry:
It doesn't bend much once it's fitted.
RevBillyG
Post Thu Jun 30, 2005 6:12 pm
Cheers :)
ian332isport
Post Thu Jun 30, 2005 6:23 pm
I'm not sure how succesful you will be with spray cans.
When a bodyshop sprays flexible plastic panels etc, they add some plasticiser to the paint to allow it to remain flexible.
Not sure if a paint factors can mix up an aerosol with plasticiser added. Probably worth a try. I guess this applies to primer and topcoat.
Ian.
