Old pioneer headunit remove?
Post Tue Dec 02, 2008 8:03 pm
What keys are used to remove it?
sati
Post Wed Dec 03, 2008 3:01 am
try with ford keys for 1996 i think iwqas teh rds 5000 or 6000 Image, or sony keys Image or kenwood Image or jvc/panasonic/pioneer Image
if they all fail , just get a 2x long(6inch) thin flat screw driver and push it in to the hole slowly you sholud feel it get stiff (you found the lock) push a bit more and leave it , get the other driver and do the same with the other hole on the same side and now put your fingers in the tape slot and pull one side sholud be free now pull out the drivers and do the other side , pull out system , fit wiring loom adaptor if not ISO conntions. and fit aerial adaptor (din to iso) if needed also
zimmer-320i
Post Wed Dec 03, 2008 3:21 am
right use 4 sutible sized nails and yank it out
sati
Post Wed Dec 03, 2008 3:26 am
or remove the centre console and just unclip it from behind ,lol or better still act like thief and rip the sucker out with 2 large flats ,lol
zimmer-320i
Post Wed Dec 03, 2008 3:47 am
yer then rip half the dash out!!! :roll:
Post Wed Dec 03, 2008 6:11 am
sati wrote: Image
They are the ones you want but you will need four. The original pioneer ones were a set of two 2 pronged tools with ends like above. And you will f*ck about for ages without them. I used to have pioneers all the time back in the day.
Very easy to make though if you have some sheet aluminium or steel.
Post Wed Dec 03, 2008 12:52 pm
B7 wrote:
sati wrote: Image
Thanks just bought it.
Jon_Bmw
Dangerous when thinking
Post Wed Dec 03, 2008 1:40 pm
You can use two(as they always come in 2's) in the drivers side one.
Remove the analogue clock which takes 2 seconds and manually release the passenger side clips with a screwdriver.
Post Wed Dec 03, 2008 11:37 pm
you might be lucky it may just pop out with a bit of help with a screwdriver,
or get the removal tool as mentioned above, although i wouldnt get them, a small selection of screwdrivers allways do the trick for me winkeye
tomtomiS
Post Wed Dec 03, 2008 11:40 pm
i had an old pioneer in the touring that had a philips screw on each side under the side trim of the headunit
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Dec 03, 2008 11:42 pm
Blitz wrote: Image
Dude thats a is a strange place to have awindow kill switch or is it just being used as a blanking plate
Post Wed Dec 03, 2008 11:43 pm
cliffybabe wrote:
Blitz wrote: Image
think its a chromie thing (1987), my chromie had it there too
