Yellow headlights
nicey
Post Sat Nov 08, 2008 3:11 pm
Hi all, I really want a set of yellow headlights like the french use, does anyone know where I could get a pair from and does anyone know how if I could get a set from France how I would change the aim over to right hand drive as they would surely be set up for left hand drive, Cheers :D
gooner1
Out humping Reindeer
Post Sat Nov 08, 2008 3:16 pm
Try the dealers nicey. Also i think E30 headlights are capable of being switched over to either l/h or r/h drive.
Someone more authorotive will answer how.
Post Sat Nov 08, 2008 9:12 pm
dips346
London Meets Main Man
Post Sat Nov 08, 2008 9:17 pm
Post Sat Nov 08, 2008 9:19 pm
what does the MOT man say about them :?
there legal in france but what about here :D
dips346
Post Sat Nov 08, 2008 9:22 pm
Alex wrote:what does the MOT man say about them :?
legal in uk as well
Post Sat Nov 08, 2008 9:26 pm
mrLEE30
Post Sun Nov 09, 2008 9:54 am
the projector lights can be swapped from right to left hand drive by looseneing the three screws on the back of the projector unit and rotating the unit from one stop to the other.
personally not a fan of yellow lights, but has anyone got a pic of smoked yellow lights??
mrlee
miniblob
Post Sun Nov 09, 2008 10:47 am
dips346 wrote:[img]http://lamin-x.com/
Legend Dips!!!!! Looks like what i've been wanting for ages!!!!!
Will speak to them about uk delivery next week!
My smoked hellas gave out a quite yellow light - i assume 'cos of the bulbs in it - but i'm going hid now!!!
Very tempted to go with a little bit of yellow on my car - i do like it!!!!!
327 Touring with bass!!!
Post Sun Nov 09, 2008 10:56 am
I got these from a fellow zoner in Belguim for £30
paddyvw
Post Sun Nov 09, 2008 11:37 am
you order the cover ie the yellow lense off the main dealer. is it easy to dimantle the lense from the body? with out cracking the glass?
aj_mckay
Post Tue Nov 11, 2008 5:19 pm
DIPS - the lamin-x stuff you used on the green touring, did you buy their E30 kit or did you buy a sheet and cut it yourself to fit? I'm going to get some but didn't know if the E30 template was good enough or if I should go for a sheet of it and cut it myself to fit... suggestions? :thumb:
dips346
Post Tue Nov 11, 2008 5:57 pm
aj_mckay wrote:DIPS - the lamin-x stuff you used on the green touring, did you buy their E30 kit or did you buy a sheet and cut it yourself to fit? I'm going to get some but didn't know if the E30 template was good enough or if I should go for a sheet of it and cut it myself to fit... suggestions? :thumb:
brought the biggest sheet which done the whole lot
nicey
Post Wed Nov 12, 2008 7:27 pm
Hi all, big thanx for every reply, dips i had a look at the lamix web site, do you know if it is sold by anyone in the uk?, was it expensive when you bought it?, this would be a simplier job than getting lights and fitting them!.
Cheers!! :D
dips346
Post Wed Nov 12, 2008 7:30 pm
yes they is a uk guy
aj_mckay
Post Wed Nov 12, 2008 8:11 pm
one more question from me Dips if I may :D Did you have to buy any adhesive with it or is it self adhesive stuff? Just about to order a couple of sheets... Tar!
dips346
Post Wed Nov 12, 2008 8:35 pm
aj_mckay wrote:one more question from me Dips if I may :D Did you have to buy any adhesive with it or is it self adhesive stuff? Just about to order a couple of sheets... Tar!
nothing else to get ,it very easy to do ,soapy water,blade and use of a hot air gun
aj_mckay
Post Wed Nov 12, 2008 8:51 pm
To quote a certain Mr. Burns.... Eeeeeggsellent! Nice one Dips.
aj_mckay
Post Mon Nov 17, 2008 12:41 pm
Dips - I've set up a thread in the group buys/discount section to get discount on this stuff through their website. I'm just waiting on the discount code from them.
I've mentioned your touring above and stuck the pic into the thread - hope you don't mind? 8)
