Where can I get some cheap Crossovers?
toby
Post Wed Oct 01, 2008 3:43 pm
To fit in the rear of my touring. I've got upgraded standard 10cm speakers with bass filters attached and a small pair of pioneer tweeters (from a set of components).
Where can I buy a pair if crossovers to match the two sets together?
Does any old 2 way crossover do it?
Nice and cheap too would be nice.
Cheers for any advice,
Toby
Post Wed Oct 01, 2008 3:56 pm
im sure you can pick some up on ebay for a fiver or so
toby
Post Wed Oct 01, 2008 4:52 pm
This is the cheapest I've found but not sure if it is exactly the right thing for the speakers/tweeters I have:
http://cgi.ebay.co.uk/Focal-Crossovers- ... 286.c0.m14
hongkongfuey
Mad-tango-geezer
Post Wed Oct 01, 2008 5:02 pm
i have focal components in the front of mine, work well imo, the tweeter output can be changed two or three settings in the crossover
with cars like mine,
secondtimelucky
Post Wed Oct 01, 2008 5:06 pm
Or you could send me a fiver and il make in-line crossovers for you, easy enough :D
Wanted: Any old component speakers, complete or separate parts, let me know what you got :D
BadDave
Post Wed Oct 01, 2008 6:28 pm
You could go active and set whatever crossover frequency you like
I've even got 2 spare active crossovers here
Might have some passives kicking about as well
Bananaman
Post Wed Oct 01, 2008 10:03 pm
if you know what ohm rating your speakers are and at what kind of frequency you want them to cross over at you could always make your own, nothing more than coils and capacitors see the link below
http://www.the12volt.com/caraudio/crosscalc.asp
but to be honest I'd go with the focals you pointed out should do the job just fine, saves messing around and look nice too.
