Removing front speakers
RICKESH
Post Thu Sep 18, 2008 3:54 pm
is it easy to remove the front speakers in cabriolet/couple i can see the screw's but the panel seems to be concealed behind the main door seal which id rather not disturb any info from those who've done it would be great
thanks
fowler
Boost Junkie
Post Thu Sep 18, 2008 4:03 pm
not to bad to remove as the just pull out and the door trim is easy to remove and replace without causing any problems
EX A-Tech Workshop bitch !!!
gone but not forgotten
liquid-24
Post Thu Sep 18, 2008 4:38 pm
Just pull it downward and will slip out the other side where the bonnet release handle is undo the bolts and will also pull down with no problems
Hope this helps
DaveD
E30Zone Wiki Specialist
Post Thu Sep 18, 2008 7:46 pm
If its a cab they are different to all the rest .... you have to remove the sill strengthener cover on the sill before taking off the door seals ..then you can unscrew the speakers..you have to take of the bonnet opener/ lever as well..a bit of a faf but about 10 minutes in all
