http://caraudiosecurity.com/shop/produc ... /1180.html
will a 12 gauge power lead be ok for the above amp, or is it a bit thin
what would the benefits be for having a thicker cable
Would 12 gauge wire be ok for 600w amp
BadDave
Less chance of it melting and catching fire when the amp is running at full power.what would the benefits be for having a thicker cable
HTH
thanks i have some 4 guage aswell, just thought if it makes no significant difference the 12 guage will be easier to fit
BadDave
Have a quick look at these tables for correct wire sizes
http://www.the12volt.com/info/recwirsz.asp
4 gauge it is then
