headrest monitors
blingsta
Boost Junkie
Post Tue Sep 09, 2008 11:25 am
Guys (kam325)..
just wanna know how or what the headrest monitors are secured in the headrest with?
do you secure them with some strong glue?
roley
Post Tue Sep 09, 2008 1:11 pm
on my last car the backpltes were screwed into the headrest (therewas a plate in the headrest) not sure on the e30 you may need a fixing kit
blingsta
Boost Junkie
Post Tue Sep 09, 2008 1:36 pm
going on my E46 mate.. me thinks im just gonna remove some of the foam and use some strong glue to hold it in place.. :D
NatDJ
Dyson deviant
Dyson deviant
Post Tue Sep 09, 2008 1:38 pm
Mine came with a plastic housing which I have cut the foam to exactly the same shape meaning zero glue, screwing required. Bare in mind you'll need plastic screws in the head rests due to HI in crash. The last thing you want is a 6" wood screw stuck in the back of your skull on impact.
blingsta
Boost Junkie
Post Tue Sep 09, 2008 1:41 pm
ive got the plastic housings mate, but not too sure even if the foam is cut to the same size if its gonna stay... i was going to add some glue!
roley
Post Tue Sep 09, 2008 2:02 pm
i will speak to my work mate he fits them for a living (outside work)i know he has done a few bm s . will let you know later
blingsta
Boost Junkie
Post Tue Sep 09, 2008 4:03 pm
cheers fella :D
Post Tue Sep 09, 2008 6:59 pm
I bought a set of headrests already mounted with the t.v's.
Case of out with the origional ones and put the others in place.
Only thing with these is that their not height adjustable.
No worries for me though, their in my wifes ML for the kids. :mad:
blingsta
Boost Junkie
Post Tue Sep 09, 2008 7:14 pm
thats the type i bought for my E30 but cant be done on my E46 unfortuneately.. they only have 1 bar supporting them and they are on the side like this, - and not like this, i .. if the makes sense
Post Tue Sep 09, 2008 7:25 pm
Oh for the e46, yea they are on a side mount, only way then is to have them installed proffesionally.If you take them out the audio guys normally send them away to be done.
Pricey mind, as I was quoted about another £120 on the price diff.
So bought the all in ones.
blingsta
Boost Junkie
Post Tue Sep 09, 2008 7:27 pm
so they do come off then? if i can take the headrest off, i will give it a go myself!
roley
Post Wed Sep 10, 2008 1:21 pm
blingsta
your headrests are they 4 way (tilt forwards/back/up/down) if so there will be a bar and poss a plastic plate under the fo
am . there are several ways to fit the monitors . i will pm you my mobile and i will talk you through it
martyn
H7AVY
Post Mon Sep 22, 2008 12:20 am
The headrests don't fit straight into the e30 headrests do they?
