60mm or 40mm Rear Drop?! Pics please!
veedubdude
Post Tue Aug 19, 2008 9:55 am
Right Ive got an oppurtunity to order some brand new supersport coilovers for just over £200, so Im going for it!
Only problem is there is two options as the rear is a fixed height, either in 40mm or 60mm. Front is height adjustable though.
Now I want the slammed look but Im running on 17s and worried about any arch rubbing issues...
Any advice/pics greatly appreciated to see the drop!! Cheers :)
Cloud
Mmmmmm Donuts!
Post Tue Aug 19, 2008 9:59 am
Both should be fine. Mine's down by 120mm. No arch rubbing issues, but it's defeated by speed humps. I've been told about drive shaft problems though, since large drops mean the driveshafts enter the diff at sharper angles, after a while the shafts and diff wear out.
I'll try and find a pic...
Hyperion
Post Tue Aug 19, 2008 10:09 am
high, if you going for the "slammed" look then the 60mm will be up your ally. with regards to the rubbing issues, that will depend on the wheel you are installing, what is the ET? and tire size for 17" are usually 205/40 R17.
veedubdude
Post Tue Aug 19, 2008 10:36 am
Im not sure of the 17 stats that are on it currently (they're the E36 M3 reps... bought it with them on), but the ones Im refurbing at the moment to go on are 17*7.5J, ET 24. The tyres will either be 215/40/17 or 205/40/17, cant remember off the top of my head!
I drive like a granny anyway so Im not bothered about speed bumps tbh; my other car is a golf which has around inch and half ground clearance, lol!
These are the alloys anyway, plan to respray them white to go on a black car:
Any pics of your drop cloud? Im guessing thats yours in your sig hyperion, how much are you dropped by?
Thanks! :)
veedubdude
Post Tue Aug 19, 2008 10:39 am
Just found a pic of when I bought her too, so you can see she needs dropping!!
lol :cool:
bigredbmw
Zone Supporter
Post Tue Aug 19, 2008 11:43 am
that looks really clean m8 ................
veedubdude
Post Tue Aug 19, 2008 2:37 pm
Cheers bud!
zaust
Zone day release
Post Tue Aug 19, 2008 8:23 pm
White on black. Can't do that !!!...
As long as the offset is correct then rubbing won't be an issue, I used to have 17"s & 60mm. But now it's 80 16...
M30 Tech 1 Touring on gas.
law
Post Tue Aug 19, 2008 10:40 pm
Cloud wrote: Mine's down by 120mm.
Holy fuucking arseholes!
Pics!!!!!!!!!
Hyperion
Post Wed Aug 20, 2008 9:58 am
Hi
My one is dropped 40mm on eibach springs, you should have no issues with rubbing. I am running 205/40R17 tires at the moment, but will be upgrading to 215/40R17 as this will give a better ride.
regards
zimmer-320i
Post Sun Sep 07, 2008 3:54 am
hi veedubdude clean car nice to see anoter clean black e30, mine needs a proper wash wax and polish but those wheel on the ca, fancy selling them to me, what size are they?? winkeye
