instrument cluster rings---please help--how to fit
anton
Post Wed Aug 13, 2008 2:04 pm
hi all
before i take the instrument cluster out of my car to fit the rings i wanted to runs some ideas by you guys, whats the best glue to use?
i dont want to screw up my instrument cluster incase i dont like em and i wanna take them off
cheers
Anton
ps: whats the best way to remove the clear cluster lens?
NatDJ
Dyson deviant
Dyson deviant
Post Wed Aug 13, 2008 2:16 pm
Removing the lens is a case of a clean stanley blade and patience. Don't rush it, as the plastic is extremely brittle and I've had a couple crack on me. Take your time and aim at taking out each blob of adhesive at a time.
The cluster rings I thought were a tight fit, therefore no need for glue. But I may be wrong.
If your in 2 minds. Why not fit them with a bit of double sided tape?
jaffro
Post Wed Aug 13, 2008 2:22 pm
thay are tight fit as i did mine and as nat says be carefull with the screen as i cracked mine :cry:
NatDJ
Dyson deviant
Dyson deviant
Post Wed Aug 13, 2008 2:41 pm
Less of the Nat...more of the Daryll. :D
Dave (d6dph) have you managed to dig out my old password yet?
Post Fri Aug 15, 2008 9:41 pm
The rings should just "Click" into place.As said above, be very carefull on the plastic. :cool:
