Engine bay tidying
BrAdZ
Post Thu Jun 16, 2005 3:42 pm
Best thing to do as I am doing with mine slowlyԚ…Ԛ….. Is take bits off and get them chromed/polished/painted/powder coated,
Use Gunk to de-grease entire engine bay (Bag up electrics)
Polish all the paint work
Zip tie bulk cables together/or out of the way
And sameco hoses I think if you can buy lengths of it from them in various sizes, and they can copy them if you have a particular one with a T piece or something
Hope this helps
Adam
A1BMW325iSport
Post Thu Jun 16, 2005 4:52 pm
firstly clean and polish the paintwork where possible, treat and rust and paint.
use bmw dealer for the pipes and clips they are pretty cheap for small clips and things
choose some enamel paint and do some detailing here and there it makes all the difference.
320Touring
Post Fri Jun 17, 2005 10:33 am
can hoses be painted?Would like to do some detailing to my engine bay and was wondering if it was possible?
A1BMW325iSport
Post Fri Jun 17, 2005 11:41 am
with the right paint i don`t see why not, i think you would need an enamel based paint
bennyp
Post Fri Jun 17, 2005 11:44 am
i think ( if i remember right ) that you can get paint specifically for rubber, that is the stuff you need for the hoses. it ends up like a rubber coating on the hose's.
enamel based would crack i think if the hoses moved :?
Cloggy Saint
Post Fri Jun 17, 2005 4:50 pm
you can get hose paint here
http://www.bmtown.com/
D2LTA
Post Sun Jul 10, 2005 7:43 am
You can buy covers for hoses, my friend had all the non-samco hoses in his R5 turbo covered with this weave design that made them look like anodysed braided hoses, very trick and a lot cheaper than the real thing. I believe he got the kit from demon tweeks.
The problem with Samcos is that they have to be the correct form for your car, if you bend them the hoses squash and collapse on the bend and restrict the flow to the point of exit.
320Touring
Post Mon Jul 11, 2005 11:04 am
D2LTA wrote: The problem with Samcos is that they have to be the correct form for your car, if you bend them the hoses squash and collapse on the bend and restrict the flow to the point of exit.
good point mate-take it the samco pipes aint anywhere as near flexible???
imagine shelling out on 'em then car cooking :cry: :cry:
