Advice required
PaulS
Post Sat Jun 28, 2008 9:58 pm
Hi,
I'm new to the zone, although I own an e34 at the moment, my 1st 3 beemers were e30's and still hold them to the highest regard. I'm after some advice - I'm after a set of smoked hella headlights and wondered whether the e30 headlights would fit, and the best place to get hold of a set.
Paul
zaust
Zone day release
Post Sun Jun 29, 2008 8:12 am
As far as I know, They are a straight fit.. So the wanted section or e-bay .
M30 Tech 1 Touring on gas.
Bananaman
Post Sun Jun 29, 2008 9:46 am
The actual lights are the same iirc, but the mounting bracket is different. All you will have to do is swap the lights over to the E34 bracket when you get them, it's an easy enough job.
gooner1
Out humping Reindeer
Post Sun Jun 29, 2008 9:53 am
Welcome PaulS,
if you look in the Ebay section, Roc a member on here has a set of smoked Hella,s up for grabs.
mrLEE30
Post Sun Jun 29, 2008 11:06 am
or read my tech article in the aticles section and do them yourself.
http://www.e30zone.net/modules.php?name ... hhella.htm
mrlee
