I've got that 2-component system a few time ago, now, i've decided to fit it into my E30. The system was fitted before on E34 tds Touring. It consists of reciever and main unit. Unfortunately, there was no connection wire between reciever/main unit. There is also BMW OEM amplifier i'v e got together with that 2 components, the model Nr. listed on the amp is 65 12 8 360 238 (actually, i can' t find this Nr. in ETK, but i believe that it is 65 12 8 361 782). A guy told that this amp also was connected with stereo system in that E34 Touring - can it be true?
Can i connect the amplifier together with BMW Bavaria C Professional RDS and if yes - which cable do i need? The Nr. i found at that time is connection cable between main unit/reciever: 65 12 8 359 039
Any ideas?
Thanks in advance,
Juris
Some pics (from e30.de)
main unit
reciever/main unit
amp i've got
