hi people got two fusion amps one to power
2 10" subs one for 2 8" do i connect together or seperate.
no instructions with amps .realy annoying
had an amp before with 4 way channel but the amp worked to hard
to get any decent sound out.i can post photo,s of amps and connectors
if helps but wont be able to do that til tomorrow.
thanks any help welcome.
how do i connect 2 amps
cliffybabe
- Powered by Nelly
what u trying to achive buddy do u mean power wise or rca wise im not bad witht he audio stuff give me a bell if u want ill pm u my number
miniblob
Power wise - i've seen many different dodgy hookups, but personally I reckon the best way is to use a distibution block. You've presumably got one cable running from the battery (via a fuse I hope!) to the amp - you would just put that cable into a distribution block, and then have 2 cables from there - one to each amp. Something like this: clicky depending what size cables you're using!
Don't for get to run earth leads from both amps too - ideally to the same point - or could use another dist block.
Remote lead is only a small current - 3 or 5 amps or something i think, so you could just link one to the other if the amps are next to each other.
Signal RCA/Phono wise - your amps have probably got an 'out' next to the input - you can just use a phono from there to the other amp if you want to make it easy.
If they haven't got an output or 'daisychain' pair, then you'll need to use a pair of splitters (clicky) and then phono's from there to each amp's input.
Might also be worth using a line driver, clicky, to increase the output from the h/u - especially if you end up using splitters!!
Hope that helps!!
Can you tell i've got nothing better to do!!
Also, just thought - if you're running with the battery in the boot and i'm assuming the amps will be in the boot - you could just run two (individually fused) +ve cables direct from the battery!!
Hope that helps!!
327 Touring with bass!!!
elf
thanks for that miniblob.
i have both that you speak of.
will give it a go and see what happens.
wait for bang.
wait for bang.
chu346
A linedriver won't be needed with only two amps, this ain't no £3000 install.
elf
thanks for input help guys.
done it.
sounds good.
off to d,class trimmers to finish
done it.
sounds good.
